Tall Rally style Coilovers
Old Apr 9, 2022 | 10:18 AM
Hvymax's Avatar
I'm looking for solid coilovers that can accommodate a slightly taller than stock ride height and work well in rough conditions. I'm sick of bending rims bottoming out on potholes.
Old Apr 9, 2022 | 10:33 AM
PulpFriction's Avatar
This guy has Malibu struts in front and PT Cruiser springs in the back, I think. Didn’t add a lot, maybe less than 2 inches? Will try to remember which generation of Malibu. 2009 sticks in my mind but not sure. Your car came with FE1 “soft ride” dampeners. Just switching to the SS dampeners might help a bit.
Old Apr 9, 2022 | 04:54 PM
Hvymax's Avatar
Holy Crap I Like it!!! Is there a thread somewhere on this car???
Old Apr 9, 2022 | 05:06 PM
Rims bend , no matter your ride height, you need stiffer side walls in your tires! And taller springs
https://www.spaccer.com/en_CA/makes-...vrolet/hhr-434
Old Apr 9, 2022 | 05:16 PM
Hvymax's Avatar
Those look good the Malibu struts look good as well. Heavier springs and more travel as well. I guess I'm going to research the Hi Jackers. None listed but I just need the correct ends and travel to work
Old Apr 9, 2022 | 05:22 PM
Hvymax's Avatar
16" dually style wheels would look awesome on this. I'll just need to turn up some spacers and adapters on the lathe. Spacer adapters for the front and thin adapters for the back. Probably 3-4" wider in the back. Hopefully truck wheels will hold up. I have 3 bent stocker's laying around.
Old Apr 9, 2022 | 06:04 PM
I’ve bent the rims on my daully, train tracks are brutal, I upgraded to more ply tires!
Old Apr 9, 2022 | 06:12 PM
Hvymax's Avatar
Crap I used to launch my truck 10' and land on all kinds of stuff and never bent the 15x8 wagon steel wheels. I generally flog my trucks, 4 wheelers etc and never bent a rim!!!
Old Apr 9, 2022 | 06:56 PM
Off road , yes they should last , but on road there’s so many more obstacles, potholes, train tracks, frost joints on bridges, curbs
Off road tires are also designed to handle and protect the rims from rocks and logs and rough landings
Callieb93
Oct 17, 2020 10:03 AM
jaime_g
Tires & Wheels
Sep 13, 2010 02:53 PM
Jaxon
Tires & Wheels
0
Jun 12, 2010 07:10 PM
BigBear45
13
Jul 20, 2009 10:53 PM
O6ChevyHHR
Oct 14, 2006 06:42 PM
