Underhood Fuses Tip
Old 10-27-2005, 12:31 PM
SoCalHHR's Avatar
Underhood Fuses Tip
The Underhood Fuse Tip can be found HERE.
(moved due to a server crash!)
SoCalHHR is offline
Old 10-27-2005, 01:12 PM
SIHHR's Avatar
I was thinking about painting the Fuse Box Cover and the other part right in front of it. They both come off easy.
SIHHR is offline
Old 10-27-2005, 05:41 PM
wheelsee's Avatar
this should be stickied!
-WC
wheelsee is offline
Old 10-27-2005, 07:39 PM
SoCalHHR's Avatar
If JonelZ makes a "Tech Tips" section, we could stick it there. If I come across anything else that seems relevant I'll post it there. But only if you guys feel this type of thing is helpful.
-Mike
SoCalHHR is offline
Old 10-27-2005, 09:53 PM
SIHHR's Avatar
We are still growing along. With Great Members like yourself and the others this site can be an ultimate resource towards the HHR.
SIHHR is offline
Old 10-28-2005, 08:27 AM
adamlowery's Avatar
Heck yea. All this kind of info is helpful. I also think there should be a type of tech tips section. It'd be nice.
adamlowery is offline
Old 01-06-2006, 01:09 AM
Pizzaman's Avatar
I was finally able to get under the hood of my "lil hearse" today and what did I find? All but one of my fuses and relays were loose. A full inspection is coming soon.
Pizzaman is offline
Old 02-04-2006, 09:23 AM
Firewatcher's Avatar
I was checking my oil and remembered reading these messages. Checked and lo and behold.......every fuse, breaker, and relay loose. My son, who works in manufacturing figures they are placed into the panel by some type of pneumatic press that uses a set pressure. That would explain the uniform looseness. You would think that when they installed the panel under the hood they would check everything. Maybe it's time to forget NAFTA and get the jobs back to the USA.
Firewatcher is offline
Old 02-04-2006, 09:26 AM
captain howdy's Avatar
Good idea! Now if our govenment could only see the light.
captain howdy is offline
Old 02-04-2006, 10:01 AM
jaydogg's Avatar
just checked mine and every one of them was loose.
jaydogg is offline
Quick Reply: Underhood Fuses Tip
