Forum Jump Gallery Videos HHR Userbars .net Decals Top Referrals Link To Us Contact Us
Supporting Vendor Index
Go Back   Chevy HHR Network > General Discussion > How to Guide > How to new Shift boot and short shifter.
How to Guide Write tips and instructions on how to install parts or fix problems.
Old 06-07-2008, 05:14 PM   #1
crazysteve
Member #: 4875
First start by removing knob top..I used a flat blade very carefully.
Then remove 25T screw in top of knob.
Carefully pry up the shifter boot and then remove the 4 20T screws around the shifter (you should see them)
Once the 4 screws are out lift up the shifter, undo the knob on the side, lift up up a little more and pry off the shifter cable on the bottom. Once that is done remove from car and disassemble the shifter. (side note the knob is a complete pain to get off, used a long punch and knocked it loose.
Then cut the shifter were it start to go straight.
slide new fancy part on and tighten down the set screws using lock tight.(still waiting to here back to be a supporting vender.)
The shifter is done and now to finish the boot, cut the zip tie from the reverse lock and shifter top and set it aside, pry out all the staples from around the bottom of the boot (PITA) slide the new boot over the black ring and then snap the chrome ring over it (I did not use staples here but you could not a need thought) slide reverse lock back in and zip tie down. Should look some thing like this.
Reassemble and enjoy. By the way the boot came from shiftstyle.com I order the cobalt one and it fit a little tight, I will be sending them my boot to I am guessing they will have one to order soon.
08 HHR SS Victory Red..HPtuned, MY IC, hotside pipe, 3" TBE, rear rollbar,SSI springs, Custom Brakes...13.11 @ 103.5
F35 w/ LSD
crazysteve is offline   Reply With Quote
Old 06-07-2008, 05:15 PM   #2
crazysteve
Member #: 4875
Side note could one of the dealer or parts people, see if the blue piece can be bought and how much..mine was broken already.
F35 w/ LSD
Old 06-07-2008, 05:24 PM   #3
GDZHHR
Member #: 1751
Nice how-to Steve. Looks great!
BTW, it was great meeting you and the gang.
MIKE
(DISCLAIMER: I am often wrong!)
"Bob" was born/built March 14, 2006
"What you do speaks so loud that I cannot hear what you say." Ralph Waldo Emerson
GDZHHR is offline   Reply With Quote
Old 06-11-2008, 11:47 AM   #4
Hotrodbob
Member #: 4136
My shift knob looks nothing like yours. Has anyone done a shifter change on an '08?
Hotrodbob
Anyone can restore a car, but it takes a hotrodder to cut one up and make it cool
Hotrodbob is offline   Reply With Quote
Old 06-11-2008, 03:11 PM   #5
tjplogg
Member #: 4433
This is an 08 SS shifter.
2008 Blacked out SS- GM STAGE 1 Kit, 5 speed w/ TWM short shifter, lsd, Aeroforce gauge, Carbon fiber overlays, IPCW LED taillights, LED licence plate lights, sunroof, performance seat, Pioneer Avic-f90bt DVD/Nav system w/ Infinity sub and amp, Compustar 2-way Remote Starter/Alarm
tjplogg is offline   Reply With Quote
Old 06-11-2008, 04:52 PM   #6
crazysteve
Member #: 4875
Yes this is on a 08SS not sure how any of the others look.
F35 w/ LSD
Old 06-11-2008, 07:57 PM   #7
Yonash
Member #: 5606
i like it. i see you posted where the boot came from, but what about the short shift kit? or did i miss that in the thread somewhere?
Yonash is offline   Reply With Quote
Old 06-11-2008, 08:02 PM   #8
shaginwgn
shaginwgn's Avatar
Member #: 1275
He is waiting on supportuning vendor status to be granted/approved...
Grey
shaginwgn is offline   Reply With Quote
Old 06-16-2008, 12:10 AM   #9
Hotrodbob
Member #: 4136
Are you saying that MFG has to be APPROVED before info can be posted about a product??
Hotrodbob
Old 06-16-2008, 01:23 AM   #10
shaginwgn
shaginwgn's Avatar
Member #: 1275
Yes if the MFG is selling the part on here afflilated with the company, or does multiple transactions and on the opening post he said he was waiting on supporting vendor status in the statement about installing the fancy new part. And is a mechanic at a saab shop so has resources like getting the bsr tuner...
Grey
vBulletin copyright ©2000 - 2010, Jelsoft Enterprises Ltd. Vb Style © vb-skins.com
©2005 - 2010 ChevyHHR.net, an Enthusiast Networks LLC website
This site is not affiliated nor endorsed by GM. All related trademarks are the property of GM.
