New 'HHR specific' splash guards installed:
Old 07-31-2009, 08:56 AM
HHR_style's Avatar
I wanted to get some splash guards for the front. I found a complete set (front & rear) HHR specific (GM p/n 88968231) for $28.50 including shipping!
Here are some of the details molded into the plastic. Go Canada, eh? Now I need to get a colored vinyl HHR logo to put on there.
Instructions- page 1:
Page 2:
With the holes already pre-drilled, this was an EASY install. They fit perfectly & look great!
First step is to remove this 10mm bolt:
Then remove the trim panel clips using your favorite garden tool. Remember, dont twist too hard:
Here's the bag of hardware that came with the fronts. They give you extra!
This is the bag for the fronts. The rear set hardware had slightly smaller clips.
I modified the front set of clips. I smashed them a bit with pliers so they would hold on to the fender tabs better (during assembly):
The clips & screws take the place of the trim panel clips.
After removing the trim panel clips, I cleaned all the dirt
& installed the threaded clips onto their respective fender tabs.
I went ahead & mounted the rears to match the front. Guess I'll toss the old rear ones out? I used a short screwdriver for the rear so I wouldn't have to remove the wheels.
Here's the fronts installed:
Here's the rears:
Here's a comparison of the old & new rear flaps:
I'll get a better overall picture when the weather cooporates & I can wash my car.
HHR_style is offline
Old 07-31-2009, 10:12 AM
WOW, the sun shines on both sides for you.....
Old 07-31-2009, 11:46 AM
Wolfie's Avatar
Did you Guys noticed ???
No Made in China crap that falls apart in no time ...
Splash Guards are Made In Canada - woohoo
Wolfie is offline
Old 07-31-2009, 12:44 PM
HipHotRod's Avatar
Paint that muffler!
HipHotRod is offline
Old 07-31-2009, 01:53 PM
HHR_style's Avatar
Paint??
Paint that muffler!
It's a stainless steel MagnaFlow:
Why would I paint that?
Old 07-31-2009, 03:08 PM
txbass06's Avatar
$28.50 including shipping is a helluva deal. Looks good
txbass06 is offline
Old 08-01-2009, 12:51 AM
For go the vinyl and use paint!!
jx3 is offline
Old 08-01-2009, 08:50 AM
hyperv6's Avatar
These are the same ones many of us have modified for the SS.
The rear ones will bolt on with a slight mod to the bolt holes and the fronts need notched for the rockers. Neither is a major modification and easy to do.
I also use silicone to fill in the back and make gasket to preseven tht flap from moving and rubbing. Dirt and small stones and abrasives do get behind them and can and will rub. I used the silicone on my molded GM truck flaps for over 11 years and it protected them well.
hyperv6 is offline
Old 08-01-2009, 09:43 AM
bigallis1's Avatar
Yes, that is a good deal...........
bigallis1 is offline
Old 08-01-2009, 10:19 AM
budmanz's Avatar
where can i get them at that price please?
budmanz is offline
Quick Reply: New 'HHR specific' splash guards installed:
