My $1.08 Lower Grille Mod on Shaggy and Shaggy Has New Teeth
Old 07-08-2006, 06:30 PM
cj krause's Avatar
That is right, I did say $1.08. They had 3 outside a package and the normal price was $6.78 for 5 and she sold them to me for $3 for 3.
I went on a quest for a grille like Sindys and walked the whole store at Lowe's. Finally ended up at the gutter area and there was all kinds of goodies. you can get dark brown plastic and they had this anodized aliminum. 5 to a ack for $6.78.
Pics and URL for product i used below
ok so this is how it installs
1. cut to 33 inches
2. Flatten the mesh so it is smooth and it bends or curves in an arch slighltly by itself. this bend matches the HHRs grille opening
3. unbend tabs on back of stainless clips pretty far out and take off mesh
4. at 9 inches in from each side and where there is a flat part on top, put the clip thru the mesh at the 3rd slot down and then take a needle nose pliers and flatten the lil tabs
you are ready to install
5. make sure that it is exactly between the 2 posts on top and align the tabs on the top of the mesh and push the clips down on the plastic rail there on the inside of the bumper. it goes on snug. the mesh goes along the top and fits snug when you do this
6. wedge the mesh against the left and right bolts coming out of the bumper ( you can buy a metric nut and a large fender washer and screw it down on the post and really secure the 2 top sides down) I didnt have time to go to Turners Hardware and find 2 nuts. i will post tomorrow.
7. gently hold the mesh flat against the hole in the bumper on the back and the with your finger tips, bend the mesh over the bottom edge and lightly and firmly pinch in place. do this all along the bottom edge and sides.
You now have a custom fitted lower grille.
this was way too easy and anyone can do this
Lowes
http://www.lowes.com/lowes/lkn?actio...57336&pad=true
Home Depot
http://www.homedepot.com/prel80/HDUS...=09-12343952-2
cj krause is offline
Old 07-08-2006, 06:35 PM
Retroburban's Avatar
Looks great, I just and I mean, just got back from HD with the same leaf guard. Iam gonna paint mine with the bedliner stuff, since I already have it.
So, use the two clips and the bolt it in with the two nuts already there?
So, I will need two metric nuts and washers, huh?
Retroburban is offline
NY HHR's Avatar
Excellent CJ, that's what I did the other day, it cost me about $8.00 all together. Excellent mod!
NY HHR is offline
Old 07-08-2006, 06:59 PM
JESSE's Avatar
I got the same deal their on Wednesday. Bought two. one for a spare.(just in case). Taking trip to Florida on friday. Did not want to get stuck without a/c. Got a couple of mods to finish monday, then will take pic's. Hey CJ, the bolts are metric #8- 1.25 they were .34 cents each in the bolt dept.
JESSE is offline
Old 07-08-2006, 07:08 PM
MikeX's Avatar
That's a good idea on the clips there.
MikeX is offline
Old 07-08-2006, 07:14 PM
txsman2930's Avatar
Woohoo! I'm excited. Got me a grille comin' when I move up there in a couple of weeks. New name for CJ....MCGUYVER
txsman2930 is offline
Old 07-08-2006, 07:39 PM
Fort Worth, I used to live there!!!!!! My family still does. How`s the weather, hope there is no tornandos. Yeah, I told my wife that we have never had any tornadoes is like 80 yrs, then I looked out my window, by I`m dumb!
Old 07-08-2006, 08:31 PM
flyhhr's Avatar
you can use the gutter stuff just watch out it will rust you can also get a 2x8 sheet of metal lathe at home depot for like 6 or 8 dollars so you can do more or a bigger piece we use that stuff for body kits. it is in the drywall area use for stucko
flyhhr is offline
Old 07-08-2006, 08:42 PM
EZ4U2CHere's Avatar
So the clips come with the mesh???
EZ4U2CHere is offline
Old 07-08-2006, 08:46 PM
Yes, two and they will pry off easily. As for the rust issue, use the bedliner stuff, and scuff it real good then wipe with alcohol. OR paint it.
I do not think the paint will last that long as it chips easily.
Time will tell.
Gutter gaurd, $1.61
2 disposable brushes, $.70
$3.01 plus tax= $3.35
Not bad insurance!!!!!!!
Quick Reply: My $1.08 Lower Grille Mod on Shaggy and Shaggy Has New Teeth
