Ignition Jamming
Old 08-15-2006, 03:19 PM
bluehhrjay's Avatar
Ignition Jamming
last week after using my remote, start entering my car I attempted to put my keys in and start the car. But the igintion would not turn. After turning off the car, and playing around for a few minutes, I finally got the key to turn, has this happened to anyone?
bluehhrjay is offline
Old 08-15-2006, 03:37 PM
SoCalHHR's Avatar
Sounds like a problem with the transmission interlock. the trans must be fully in "P" for the key to turn. Also, when the HHR is remote started, the trans will not shift out of "P" until the key is insterted and turned. Make sure your ride is fully in "P" when parking. If this problem persists, see your dealer and have them adjust the transmission interlock.
Hope it helps,
SoCalHHR is offline
Old 08-26-2006, 10:20 AM
machinistlady's Avatar
I had this happen once but wasn't using the remote start, just trying to get the key to turn in the ignition. I think what released mine, was jiggling the steering wheel. Seemed to have tension on one side as it was turned into a parking spot.
machinistlady is offline
Old 08-26-2006, 11:56 AM
I've had the opposite happen to me. Got home one afternoon, parked in the driveway as usual, put in park, and remove the keys. But the ignition would not release the key!! No matter what I tried, the keys were just stuck. Resigned myself to take to the dealer the next morning. But for some reason, when trying to remove the key in the evening, it came out as if nothing was ever wrong.
There have been several here that this has happened to.
jx3 is offline
Old 08-26-2006, 11:58 AM
Retroburban's Avatar
Same thing with mine.. just jiggle the steering wheel. GM has had a problem over the years with numerous different vehicles and the locking steering wheel! Still wouldn't trade it for anything!
Retroburban is offline
Old 08-26-2006, 12:00 PM
SoCalHHR's Avatar
Transmission interlock again. If this happens again, put the vehicle in gear again (D), then fully put it into "P" again. Should fix the problem.
Also, if the HHR is on a slope, the trans could be binding up from pressure. Using the parking brake (if properly adjusted to keep the car from moving), before moving the shifter into Park, should cure the problem. Same with the steering wheel above - a slight twist will release the key.
Hope it helps,
SoCalHHR is offline
Old 08-26-2006, 12:12 PM
Hope it helps,
Actually it didn't help in the least. Between myself, my wife, and a friend, we must have shifted the shifter at least a hundred times, going through all the gears. Even went as far as to take a couple laps around the neighborhood, shifting through all the gears. It just gave up the key, without anyone having to jump through hoops, on a random attempt to get the key.
jx3 is offline
Old 08-26-2006, 12:54 PM
SoCalHHR's Avatar
In that case I would return to your dealer and have the transmission interlock adjusted. There have been a few, isolated reports of interlock adjustment problems. This is sounding like one.
Hoep it helps,
SoCalHHR is offline
Old 08-26-2006, 10:36 PM
cshaberts's Avatar
there has been a slight problem with the cobalt/hhr ignition cylinders, i bet that's what it needs.
cshaberts is offline
Old 08-27-2006, 09:13 PM
Hoep it helps,
Had stopped at the dealer to report the problem. Hopefully they put it on file for future reference.
jx3 is offline
Quick Reply: Ignition Jamming
