ADM Turbo Back Exhaust
Old 02-18-2011 | 05:02 PM
Martial Law's Avatar
Who do I get in touch with to get the ADM exhaust? I read there are different set ups (muffler, diameter pipe, etc.) with this system. Is this true? Any info is appreciated.
Old 02-19-2011 | 10:02 AM
foolmoon_design's Avatar
ADM left the HHR platform a long time ago.
Currently the 2.0 boasts a 2.5" tubing, 2.5" DP, and a pretty restrictive cat.
The aftermarket exhaust systems are 3" setups. Look at Hann and Magnaflow #16811.
There are also several DP offerings from off-road to hi-flow cat also in a 3
" setup.
Search the site!
Old 02-19-2011 | 10:24 AM
gcsd3742's Avatar
I did the Magnaflow #16811 muffler and had my local shop make me a exhaust system and down pipe catless and with the y-pipe for my DMH Electric Cutout
Old 02-19-2011 | 11:41 AM
RobSSTurbo's Avatar
Got any pics of your setup? Thats awesome setup.
Old 02-19-2011 | 11:44 AM
gcsd3742's Avatar
should be in my pics.....you might have to scroll a litttle bit to find it
Old 02-19-2011 | 11:47 AM
I also have in the past bought the muffler of choice and had my local shop do a 3" stainless steel pipe ran cat back and delete the catalytic converter. Any ideas on a muffler/cat delete(down pipe) or setup for a custom exhaust? On my previous car I had a tune to cancel out the CEL to run the 3". Will the GM tune allow this?
Old 02-19-2011 | 05:34 PM
gcsd3742's Avatar
no it will not....You have to tune it out I had it done with HP Tuners....
Old 02-19-2011 | 11:32 PM
What is the SW exhaust?
Old 02-20-2011 | 06:18 AM
gcsd3742's Avatar
I'm not sure where did you get that from? (What is the SW exhaust?)
Old 02-20-2011 | 08:19 AM
SW- I think he is talking about "Stainless Works". One or two guys have this. Most have custom or off the shelf.
To clear up a little confusion....
if you leave your CAT and DP, then you don't have to re-tune for the exhaust. The GMTU cancels the ECM's Learn-Down feature. However, GCSD is correct when he states that CEL's will be thrown with an aftermarket DP w/without CAT's.
Also, be carefull. The 2.0 has an extra O2 sensor, and requires 2 bungs no matter what. ZZP, has the bungs at the wrong angle and needs a tune to work properly. HANN has 2 bungs and is the only company offering a longer DP for the Automatic. You can also get a DP with a hi-flow cat and 2 bungs that won't require a re-tune although you may occasionally throw a clearable cel (O2 related)
the HP gains are most noticable from the DP (around 15-20) the exhaust gets you maybe another 7hp.
With the comp systems in these motors your best bet is to GMTU first, add all your mods, then re-tune for effect.(Trifecta, or HP) either of these tunes are good, just make sure you get a good tuner.
Happy modding
