Ait sensor readings?
Old 03-28-2011 | 11:10 AM
OVRBOOST's Avatar
Just curious if I understand my ait sensors locations. My Aeroforce gauge has Ait and Ait 2. Ait is taken at the MAF right behind the airbox and Ait 2 is taken at the MAP in the lower charge pipe after the intercooler, correct?
Thx
Old 03-28-2011 | 11:50 AM
bartSS's Avatar
Correct sir
Old 03-28-2011 | 09:56 PM
1Panel2NV's Avatar
Intake Air Temperature
Old 03-28-2011 | 11:06 PM
OVRBOOST's Avatar
Well that is good. That means my new intercooler is working great. However, my inlet temps seem to rise a lot more than I thought they would. Is this common? I thought it was because I had my airbox lid spaced up, but I just sealed it back and my temps still rise about 10-15 degrees when I am under boost. This really isn't a problem, my new intercooler is keeping my ait 2 temps the same as normal or only raising a degree or so. What is going on here?
Old 03-29-2011 | 08:22 AM
bartSS's Avatar
When youre boosting hard it gets hotter under the hood but if youre within a couple degrees of amibient IAT2 then youre good man
Old 03-29-2011 | 11:58 AM
asanti's Avatar
Agreed. As long as your IAT2 temps are only a degree or two above ambient you're good to go. That's the air that's going into your throttlebody/intake manifold so THAT'S what you want to have at the coolest temps.
Later
Allex
Old 03-29-2011 | 09:25 PM
THE BATMAN's Avatar
Not sure this is acurate but , I see 1-3 degrees lower than ambient in IAT-2 .
Not sure if it's a wind chill effect with the CAI or what. (it's been cold For what seems like a year )
IAT fluctuates quite a bit.
Anyone else get these type of reading with the scan gauges ?
Old 03-29-2011 | 09:45 PM
1Panel2NV's Avatar
Mine is usually a couple degrees above ambient when I'm cruising. It can climb over 100 pretty easy after a couple pulls. I have seen over 150 on the dyno (not good).
Old 03-30-2011 | 04:18 AM
IgottaWoody's Avatar
I'd say ..maybe...the airs heating up thru resistance, since the air is pulled from the outside ..more air more friction more heat....try a larger intake hose
Old 03-30-2011 | 06:16 PM
1Panel2NV's Avatar
It's normal...boost creates heat.
