Anyone running the Modern Performance DP?
https://www.chevyhhr.net/forums/hhr-ss-45/cobalt-dp-29654/
YES for the 5 speed trans, they all interchange.
HHR auto DP is 1" longer, also the HHR auto 1st cat is in a slightly different location & angle.
A 5 speed factory DP in an auto HHR will have the 1st cat slightly rubbing againest the sway bar. And the stock cat-back will rub at the gas tank, unless you add 1" in length of the cat-back in the resonator section of the stock cat-back.
The Magnaflow cat-back will work ok, no adjustment needed.
excellent 'all-you-need-to-know' thread on downpipes.
http://www.cobaltss.net/forums/showthread.php?t=198998
https://www.chevyhhr.net/forums/showthread.php?t=29654
or in the DP you order. You can ask your DP maker to add an inch.
So if im doing just the DP i need to ask Modern Performance to add 1inch to the length of their downpipe since i'm automatic?
This seems to be more a pain than it's worth since i can't buy parts that bolt right up, Damn auto
Honestly, just make sure you tell them that it's going into an HHR SS w/ an auto tranny when you place your order. It's that simple!! Take a look in my gallery as I have pics of the exhaust install and you can see how the DP fits (well, Hahn's version anyway lol). I knew NOTHING of "shorter or longer" DP's when I ordered mine last year and haven't had any issues with the DP hitting the sway bar (I don't see how that's possible?? but W/E) nor any rubbing up front. Like I said before the only issue I had was with the hanger over the axle slipping off, but I fixed that and haven't had any more issues. My cat back has never rubbed/hit the gas tank either. Just my .02. Like I said, make it clear what it's going into when you order and you should be fine.
Later
Allex
Later
Allex
xzombiex66
07-29-2009 04:58 PM
Don Juan
2.2L Performance Tech
10
03-13-2008 06:28 AM
