blow throu?
Old 12-10-2010, 12:19 PM
coreycooper's Avatar
ok then ill give it a shot minus the bov and if needed later ill ad it and block off the factory
coreycooper is offline
Old 12-10-2010, 01:14 PM
rallycobalt06's Avatar
Originally Posted by 1Panel2NV
Relocating the MAF will improve fuel response. It pretty much eliminates the rich spike right at WOT. Like rallycobalt said, a bov isn't necessarily needed.
i didn't say that. please re-read my posts.
save your money..... just get the following: catless downpipe, hot side charge pipe & custom tune
you'll need the money you saved for a pack of Depends (adult diapers).
rallycobalt06 is offline
Old 12-10-2010, 02:24 PM
Gas Man's Avatar
Thanks guys for some turbo education... it's been a good read.
Gas Man is offline
Old 12-10-2010, 05:15 PM
1Panel2NV's Avatar
I thought you said a bov wasn't needed. I'm not seeing what the problem is. Am I having trouble comprehending things?
1Panel2NV is offline
Old 12-10-2010, 07:00 PM
it's highly recommended that if you were to do a MAF relocation to run a vta style bov and remove/block off the factory recirc bpv.
Old 12-11-2010, 01:11 AM
DP on its way, tune at my finger tips, Charge Pipe soon in the works
Old 12-11-2010, 05:28 AM
1Panel2NV's Avatar
Please explain further. That's not what I have heard.
Old 12-11-2010, 10:56 AM
to recirc is pointless if you dont have to (via maf relocation) because your just reintroducing Pre-Heated air back into the turbo witch is a big no no that is one of the main reasons to vent to atmosphere
Old 12-11-2010, 10:57 AM
also... does any one sell just the hot side charge pipe by itself?
Old 12-13-2010, 07:18 AM
bartSS's Avatar
Im pretty sure that every vendor can sell you just the hotside.
bartSS is offline
Quick Reply: blow throu?
