Cut hood - Cold Air Intake
Old 09-02-2009 | 06:57 AM
  #31
foolmoon_design's Avatar
I really like what you did, but why did you opt for a functional scoop in the middle of the hood? I know you would have to have cut the hood frame member to center it over the air-box but IMO it would have functioned better, asthetics aside, it appears to me that you are mixing engine air with outside air? throw any codes yet?
Old 09-06-2009 | 11:47 AM
  #32
THE BATMAN's Avatar
No codes , runs perfect. As far as off setting the scoop, IMHO it would look like s-it. To me it would make more sense to direct the air to the box, it is not that far off, as half of the scoop is over the air filter.
Old 09-06-2009 | 12:01 PM
  #33
THE BATMAN's Avatar
Talking
Everybodys got great ideas about this mod, And i appretiate it. Some cheap, some pricey.
I have less than $ 300.00 dollars total in mods to my SS, probally more like $ 200.00 ( some paints , some custom cut decaling, free short shifter , $15.00 hood scoop (custom) Mostly a lot of detail work and sweat.
But i can tell you this mod has increased performance, sound, it runs cooler , And i don,t have to listen to all the banter about the plastic stick on scoop.
Have a great weekend everyone !!!!
Old 09-06-2009 | 12:06 PM
  #34
Neogenic's Avatar
Good for you. I think it is bad ass. The others can keep sipping the haterade.
Old 09-06-2009 | 12:14 PM
  #35
camaro98z28's Avatar
All that matters is that you like it. :)
Old 09-06-2009 | 03:54 PM
  #36
THE BATMAN's Avatar
Thers some new pics in the gallery of the new grill for the scoop, Very simular to the rest of the SS' grilling.
Old 09-08-2009 | 05:43 PM
  #37
THE BATMAN's Avatar
What were they made of, Im thinking a screen type material . ?
Originally Posted by IgottaWoody
all it takes is a air deflector to " knock" the water/dirt out of the air stream but still allow the air to travel freely...used to do the same thing on dirt cars for the radiator( mud deflector)
Old 09-08-2009 | 06:20 PM
  #38
Sno White's Avatar
Originally Posted by ScreaminBlkSS
And to the ones that say it's crazy, I say , it's just a hood , It's replaceable.
Not my type of thing, but you are right the vehicle does not care. It is an inanimate object, it does not care if it gets door dings, paint chips, slots or holes drilled into it. The only thing anal about a vehicle is the driver.
While moving I think you’ll do Ok with the rain & snow, as a lot of it will be directed over the air filter box. What moisture does get on the filter will only partially cover it and then be heated by the engine and evaporate – hopefully.
Old 10-11-2009 | 07:30 PM
  #39
THE BATMAN's Avatar
New air filter and some new pics in the gallery. It's been running like a raped ape !!!!!!!!!
Old 10-20-2009 | 01:10 PM
  #40
cva617680's Avatar
Keep us informed on the final process. I would like to do the same thing. Did you build the scoop yourself or by it?
Quick Reply: Cut hood - Cold Air Intake
