Dejon BOV spring installed
I installed the bov spring from dejon, my check engine light came on. im thinking that this has something to do with the air flow sensor due to more restriction from the spring. Am i correct, or am i completely wrong please advise.
Thanks
Thanks
Wrong, I ran the Dejon BPV spring from 600 miles till 4k miles without any lights/codes. You don't need the Dejon spring, only reason I had put one in was my stock BPV spring was staying collapsed in the diaphragm, I recently switched back to the stocker and the original problem seems to have disappeared.
So now I'm back on the stock spring and I would advise the same unless your having issues with your factory spring..
Yeah i went to autozone today code:p2261. The only problem i was having was some weird noises, and i had no clue what it was and the dealership doesnt know dick about turbos, so i tried switching out the spring but i still have that noise. does either of your guys wastegate or something make like a fluttering sound? because mine does and i have no clue what it is.
