Difference between manual and automatic
Old 06-30-2008, 01:06 PM
Motorhead's Avatar
Thumbs up Difference between manual and automatic
I see that the HHr list the 260 hp on the manual and 235 hp on the automatic! Can anyone tell me what changes they made so I might boost hp on a automatic? Maybe a chip or power module? Also has anyone heard what they are going to do for the 09 model in the way of engine hp? Thanks
Motorhead is offline
Old 06-30-2008, 04:39 PM
SSROADSTER's Avatar
hello and welcome......check out this section, along with the SS section. use the search, there are quite a few threads and many posts with all of the info you are looking for. The PPC tuner is out and available, but the auto version is still being worked on.......there will be choices in the future.....
SSROADSTER is offline
Old 06-30-2008, 08:09 PM
Chevy SS's Avatar
I am willing to bet they aren't changing the power for the 2nd year of production. But yes, a PPC tuner would boost the power (when the auto is available) standard bolt ons such as exhaust and intake would help out a bit as well.
Chevy SS is offline
Old 06-30-2008, 09:47 PM
405HP_Z06's Avatar
I've seen many different horsepower ratings for the A4 SS and from what GM Powertrain lists as the SAE J1349 test the A4 is 250 HP peak but limited to 222 lb/ft torque due to the maximum torque rating of the transmission. Horsepower is limited in 1st and 2nd gears by limiting maximum boost.
In case you haven't seen it, here is the SAE certified J1349 dyno graph:
405HP_Z06 is offline
Old 07-03-2008, 02:51 PM
jerSSey HHR's Avatar
So the auto should have plenty of HP for higher speed passes on the highway, correct?
jerSSey HHR is offline
Old 07-03-2008, 03:14 PM
405HP_Z06's Avatar
Correct. 1st and 2nd gears are boost limited to 235 HP. At highway speeds in 3rd and 4th gears, the max HP is 250.
Old 07-04-2008, 12:06 PM
awesome
Old 07-27-2008, 12:02 AM
bobiroc's Avatar
Unless you are planning on Racing your SS I think the stock HP with an Auto is plenty. It has plenty of power that kicks in when you need it. I think once you get yours you will find that to be true. Wouldn't the dealer let take on for a spin? or didn't they have one? I took one on a 20 mile ride before I bought it and I was like this little thing has a WOW factor.
bobiroc is offline
Old 07-27-2008, 08:53 AM
Lone Ranger's Avatar
You can't get limited slip differential with the automatic. There is an after market limited slip differential available for the 4T45E automatic transaxle, though.
Lone Ranger is offline
Old 07-28-2008, 04:09 PM
Dealer only had a 5 speed so I drove that. I intend to drive the auto in the next couple days.
Quick Reply: Difference between manual and automatic
