Exhaust from A to Q
Old 08-28-2009 | 03:14 PM
XXL's Avatar
XXL
Exhaust from A to Q
... since I'm not done, there is no Z.
Step 1, Start laying overpriced parts in kitchen floor so wife can raise hell...
Old 08-28-2009 | 03:17 PM
XXL's Avatar
XXL
In order to maximize ground clearance and to do something a little different (oh, and to spend lots and lots more money than if this stuff was round ) I went with ovalized stainless in what nets out to 3" diameter (2.125" x 3.5")
This exhaust will be a 1:2 with side "zoomies" exits...
Last edited by HillsdaleHHR; 08-28-2009 at 07:01 PM. Reason: Reduced pic sizes to max 640 x 480!!!
Old 08-28-2009 | 03:18 PM
XXL's Avatar
XXL
$1xx.xx in scraps
Last edited by HillsdaleHHR; 08-28-2009 at 07:01 PM. Reason: Reduced pic size to max 640 x 480!!!
Old 08-28-2009 | 03:19 PM
XXL's Avatar
XXL
Out with the old...
In with the new...
Old 08-28-2009 | 03:20 PM
XXL's Avatar
XXL
Getting things fabbed and tacked up. I'm using v-band clamps from end to end to make sure I get a solid, but serviceable connection.
Old 08-28-2009 | 03:21 PM
XXL's Avatar
XXL
Fitting and refitting until I can't stands it no more...
Old 08-28-2009 | 03:22 PM
XXL's Avatar
XXL
This shot gives you an idea where the exits will be headed. It also makes more clear the reason for going with ovalized tube.
Old 08-28-2009 | 03:24 PM
XXL's Avatar
XXL
Hangars on and bolted down...
This is a temporary exit. I'm building some tips that will integrate better with the rocker. Finished exhaust is no lower than the factory. These straight pieces had to be at this hight to clear a body pinch weld that you definitely don't want to cut into... since it's what hold the bottom of the car body together. The tips will help me get the exits back where I want them.
Old 08-28-2009 | 03:26 PM
XXL's Avatar
XXL
Tip time. I didn't take very many pics of this process.
Weeks turned into months, but here are craptastic camphone pics of the final tips I recently finished up. Two ovals were 'siamesed' together to get the size I was looking for, and then the opening was bordered with a piece of .25" round 304 stock that was heated and bent around a form. Once they were joined, it was time for LOTS of grinding, sanding, and eventually polishing to make the thick lip look like one piece on the tip.
Old 08-28-2009 | 03:28 PM
XXL's Avatar
XXL
And now that the big snail is on, I rolled the 1.5" WG tailpipe back into the downpipe to keep the noise down.
