GM Performance Parts Turbo Upgrade Kit
Old 12-14-2008, 08:43 PM
  #141
c2vette's Avatar
Originally Posted by mightymouse
i got dynoed with just the tune only i put out 261 to the wheels. so stock, should be around 240ish. i never go by crank hp. with that being said,going from 260 to 290 crank on the gm,to the wheels you are looking at about the same.
OK, that makes sense, let's hope somebody compares the two on a dyno. In the meantime here are the dyno curves stock vs Basic Hahn/PPC tune (scroll down) http://www.turbosystem.com/New_Folde...ent%20Page.htm
c2vette is offline
Old 12-14-2008, 08:44 PM
  #142
Chevy SS's Avatar
Originally Posted by c2vette
There are plenty of dyno charts and details on other threads that show these numbers, and the increase from stock. For now, the GM tune offers a warranty (big plus), but not as much HP as the Hahn/PPC (not surprising). The dyno results show the increase from stock, so the type of dyno is not really that relevant as it would be if you were talking only absolute numbers.
Exactly. I will go for a tune with less HP but keeps the factory warranty VS more hp and no warranty. Throw on the IC and piping and a turboback and it's all good.
Chevy SS is offline
Old 12-14-2008, 09:50 PM
  #143
turbotech's Avatar
I hope the kit will be in tomorrow. Maybe tues. I will be getting a few pulls on a dynojet tomorrow after work as a base line. The way I look at the GM tune is, that it allows the ecm to not be restrictive on air flow. The more the engine breathes the better. Exhaust, i.c. piping and cai. So I think an aftermarket program would enhance the power output. Also, FYI. Found out from Henderson performance that EFILive will not be doing anything with the Bosch ECM. I will post results before and after.
turbotech is offline
Old 12-15-2008, 06:13 AM
  #144
gcsd3742's Avatar
So no EFI LIVE huh....Guessing you'll have to bring your ARSE down for sure now and get the FLACO tune(Come over to the fast side "FLACO TUNING"). Got a futon for ya....And yes We'll post up the before and after Dyno runs on both the auto and standard. before and after the tune as well....
gcsd3742 is offline
Old 12-15-2008, 07:11 AM
  #145
camaro98z28's Avatar
Originally Posted by camaro98z28
This sounds like a great deal. From what I got from it is even if you add a larger exhaust system, you won't gain anymore power than this Stage 1 kit adds? Let me know if this is correct.
Bump!
camaro98z28 is offline
Old 12-15-2008, 09:50 AM
  #146
gcsd3742's Avatar
Just got verification my Turbo upgrade kit just arrived at the dealer YIPPEE
gcsd3742 is offline
Old 12-15-2008, 12:55 PM
  #147
AaronSS's Avatar
Bump!
I gathered just the opposite. Because there is no learn down, aftermarket mods will show gains instead of the ECU learning itself down to the "set" power level.
AaronSS is offline
Old 12-15-2008, 01:09 PM
  #148
esmarkey's Avatar
Bump!
That's how I understood it (Aaron SS post) as well, maybe Bill "more torque more HP" will respond, that is if he can tell us (liability you know)
esmarkey is offline
Old 12-15-2008, 01:40 PM
  #149
esmarkey's Avatar
Bill, while I have you, someone questioned the durability of the auto tranny with the upgrade so I went and looked up the specs for the manual (what I have) and found the following:
2008 GME Sweden F35 ( MU3 ) 102207
Type: transverse front wheel drive, five-speed manual transaxle ( optional with limited slip differential )
Engine range: 2.0L I-4 turbocharged (LNF)
Maximum engine torque: 260 lb-ft ( 353 Nm)
Maximum gearbox torque: 260 lb-ft ( 353 Nm)
Do you know if the specs for these transmissions are really accurate?
I know I will keep my factory warranty, but still would like to know for after the 100,000 miles is up.
Thanks in advance,
esmarkey is offline
Old 12-15-2008, 01:41 PM
  #150
Ok I miss read this statement.
Originally Posted by More_Torque_More_HP
You are correct on the production calibration. The Power Upgrade basically turns off the learn down feature and is tuned to protect the turbo from overspeed. Therefore, if you add something to make the engine breath better this kit will keep the horse power gains that part made. There is no specific set boost level.
Sorry, I can not give out any information on future products.
Looks like more mods would help out more.
Quick Reply: GM Performance Parts Turbo Upgrade Kit
