GM Performance Parts Turbo Upgrade Kit
#162
That is correct, the Power Upgrade kit does not learn down like the production. The Kit is only interested in maximum turbine speed. SO if you make the system run more efficiently you see the power gains stay.
#163
Transmission Specs
Bill, while I have you, someone questioned the durability of the auto tranny with the upgrade so I went and looked up the specs for the manual (what I have) and found the following:
2008 GME Sweden F35 ( MU3 ) 102207
Type: transverse front wheel drive, five-speed manual transaxle ( optional with limited slip differential )
Engine range: 2.0L I-4 turbocharged (LNF)
Maximum engine torque: 260 lb-ft ( 353 Nm)
Maximum gearbox torque: 260 lb-ft ( 353 Nm)
Do you know if the specs for these transmissions are really accurate?
I know I will keep my factory warranty, but still would like to know for after the 100,000 miles is up.
Thanks in advance,
Thanks in advance,
#166
#168
#170
Whooooo Hooooo my kit came in at my dealer yesterday. Now I just need to set up the install
Let's hope we quit getting so much snow around here so I can see what kind of gains I get with the butt dyno
