Great customer service -forge motorsports
3 months ago i installed their blow off valve & since i have the gm upgrade tune & based on people's suggestions on this forum, i used the heavier yellow spring. now the check engine light comes on almost daily. i have a scan tool, so erasing the code was no big deal. code p2261 turbo bypass valve stuck closed. i called forge & they told me to use the lightest spring that will work for my application & that the yellow spring isn't needed just because it's got the gm upgrade tune. i told them that i don't have the green spring anymore & forge told me they will send me one - no charge!!!!
well, i guess you get what you paid for. in this case, nothing, yet. so, after 1 week, i still didn't get the green spring in the mail, so i called forge & the guy that i talked to last week wasn't in & another guy said there's no record of any spring being sent to me. so the 2nd guy said he will send me the spring. meanwhile, after a hard accel, the check engine light came on AGAIN! it only comes on after a hard accel w/ the same p2261 code.
thanks for the offer. i'll give it 1 more week to see if they send me the green spring. you don't get any check engine light w/ the yellow spring? ever since i installed the forge valve w/ the yellow spring, i get a check engine light, but only after a hard accel at 1/2 to 3/4 throttle, usually from a roll.
