Great customer service -forge motorsports
Old 09-27-2012, 01:53 PM
andyb's Avatar
Thumbs up Great customer service -forge motorsports
3 months ago i installed their blow off valve & since i have the gm upgrade tune & based on people's suggestions on this forum, i used the heavier yellow spring. now the check engine light comes on almost daily. i have a scan tool, so erasing the code was no big deal. code p2261 turbo bypass valve stuck closed. i called forge & they told me to use the lightest spring that will work for my application & that the yellow spring isn't needed just because it's got the gm upgrade tune. i told them that i don't have the green spring anymore & forge told me they will send me one - no charge!!!!
andyb is offline
Old 09-27-2012, 02:06 PM
solman98's Avatar
It's too bad more compainies are not like that. That's the kind of service that will bring you back and give recommendations.
solman98 is offline
Old 10-05-2012, 09:32 AM
andyb's Avatar
Unhappy
well, i guess you get what you paid for. in this case, nothing, yet. so, after 1 week, i still didn't get the green spring in the mail, so i called forge & the guy that i talked to last week wasn't in & another guy said there's no record of any spring being sent to me. so the 2nd guy said he will send me the spring. meanwhile, after a hard accel, the check engine light came on AGAIN! it only comes on after a hard accel w/ the same p2261 code.
andyb is offline
Old 10-05-2012, 09:36 AM
I have two green springs, let me know if you want one, I'll give one up, I only have one SS,
SS fan is offline
Old 10-05-2012, 11:14 AM
andyb's Avatar
thanks for the offer. i'll give it 1 more week to see if they send me the green spring. you don't get any check engine light w/ the yellow spring? ever since i installed the forge valve w/ the yellow spring, i get a check engine light, but only after a hard accel at 1/2 to 3/4 throttle, usually from a roll.
andyb is offline
Old 10-05-2012, 11:29 AM
I bought the 4 spring kit when I got mine, it throws a code with the blue spring, but the yellow works fine. I have trifecta tune, set at 25lbs.
SS fan is offline
Old 10-05-2012, 12:53 PM
XtremeSS's Avatar
Andy, are you sure you didn't install the valve with the opening facing upward? The opening should face down to divert the air quickly.
XtremeSS is offline
Old 10-05-2012, 02:11 PM
Joe Schulte's Avatar
My question too, as I never heard of a Forge throwing a CEL due to the spring. Could be getting stuck too and require luuuuube .
Joe Schulte is offline
Old 10-05-2012, 07:55 PM
Well I did say my spring threw a code two posts ago, maybe you think I'm insane ?Or I couldn't possibly have bit of knowledge. If he is only running the stg-1, it could be the culprit, just saying.
SS fan is offline
Old 10-05-2012, 08:47 PM
Needs a luuube and tune?
Quick Reply: Great customer service -forge motorsports
