hahn charge pipes???
Old 12-14-2010, 05:28 PM
coreycooper's Avatar
ok.. im new to this.. please no more abriaviations because there only used on the board so when i google it i end up back here.. real names or web sights only please lol
coreycooper is offline
Old 12-14-2010, 06:38 PM
Originally Posted by TurboTechRacing
Cobalt setup is different, as Hahn has 2 part numbers (1 for cobalt and 1 for the HHR). They are close to the same route but slightly different from what we hear.
Hahn is a high nickel steel we believe.
Order through us if you wish, as we are a cheaper than going Hahn direct.
Any questions let us know.
sounds like expensive garbage (although your price is better)... steel charge pipes coated or not means rust, no thanks (not your fault obviously)
Old 12-14-2010, 06:51 PM
09 Silver Bullett's Avatar
C.I.A. = Clear Image Automotive
09 Silver Bullett is offline
Old 12-14-2010, 10:37 PM
foolmoon_design's Avatar
I talked with CIA... they said a tune was required with their pipes.
Steel does rust, but after 3 years the only thing I've seen under the hood, was dust.
I just put these on.
foolmoon_design is offline
Old 12-15-2010, 08:52 AM
bartSS's Avatar
You should tune with any pipes since the car is seeing more air. Theyre just telling it how it is
bartSS is offline
Old 12-15-2010, 11:12 AM
They tried to make it a "package" deal, another tune will come but I don't see the point in tuning just for the pipes, I still have more toys to add, then tune it again. so far the GMTU will suffice.
Old 12-15-2010, 12:38 PM
Gas Man's Avatar
Do any of those tubes mount in the middle on top of the motor where the stock one mounts to, next to the air box?
Gas Man is offline
Old 12-15-2010, 01:05 PM
bartSS's Avatar
No because theyre solid. The stock piping mounts there because it has those flexible ends so it moves around n such
bartSS is offline
Old 12-17-2010, 01:29 PM
Gas Man's Avatar
True... so these aftermarkets are solid... hmm.. didn't know that.
Gas Man is offline
Old 12-17-2010, 01:47 PM
bartSS's Avatar
sorry to thread jack but thats this BBQ all about cus i would wanna come out
bartSS is offline
Quick Reply: hahn charge pipes???
