Interesting message today from GM
magnuson-moss act
check it out
Stop worrying about your warranty, have fun with your car...
do the after market stuff!
make it hot!
and then when Chevy dealerships come at you tell em
"read it and wee..no better yet read it and fix that sh*t!"
glad i could help!
*have you ever seen a chevy with the butterfly doors? i have...i own one:)
check it out
make it hot!
glad i could help!
Went through it with GM on my Vibe, added, GMPP S/C, engine rod snapped, took it to dealer, dealer refused warranty. Went all the way up to GM, they said if it is indeed a GMPP AND was installed by an authorized installer, THEN it is covered, if not, you my friend are assed out! $900 and some hrs work later I had a new/used engine with less miles than mine had on it (22k!). I had to by the engine from a CorollaS at a local yard and un/install it myself. They would not touch it under warranty.
Correct assumption. They themselves would have to eleminate the ristrictions. I have a feeling that it's a Program, Piping, and Filter change. Should cost about $600.
#27
I can see some nice options with the 255 kPa cap removed, then the Hahn tune as a new baseline and then the HPC on top of that to do your own mods from there. Gets expensive, but a nice tune could be had.
#29
#30
This surprises me also. Injector duty cycle's are currently super low, leaving plenty of head room. From what I've seen so far, the stock fuel system has no issues keeping up with the current 255 kPa limit.
