stock injectors, rated for how much hp
Old 04-28-2012 | 08:15 PM
cannuck's Avatar
with my buick regal i had to upgrade the injectors as the hp increased. what can these handle before an upgrade is needed.
thx dave
Old 04-28-2012 | 10:48 PM
prod's Avatar
I havent heard of anyone here needing to upgrade the injectors. Direct injection and the massive fuel pressure make for a high threshold, around 500hp.
Old 04-28-2012 | 11:24 PM
XtremeSS's Avatar
the factory pump can easily support over 450 ft lbs of torque and more than 500whp at 6000 rpms while running gasoline<<<. This is taken from ZZPs website. Read more here: http://shop.zzperformance.com/store/...ge-1-Cams.aspx
Old 04-29-2012 | 01:11 PM
RobSSTurbo's Avatar
Shouldnt have to upgrade the stock injectors unless your big turbo and i mean big turbo.
Old 04-30-2012 | 03:18 AM
ATLsilverSS's Avatar
.....or running full e85 on stock turbo, or a blend on an upgraded turbo
Old 04-30-2012 | 01:45 PM
EcotecRacer's Avatar
I agree here full e85 on stock unit will max the injectors
Old 04-30-2012 | 02:46 PM
Turbo Hearse's Avatar
sure thing. Multiple cobalts blow their injector seals running e85. I guess there are upgraded ones though
Old 04-30-2012 | 03:15 PM
rallycobalt06's Avatar
in order to safely run full E85 on stock turbo, get the ZZP 5th injector setup.
Old 04-30-2012 | 03:19 PM
agreed
waynenelson09
05-22-2015 09:46 PM
843de
Tires & Wheels
10-03-2011 11:45 PM
captain howdy
07-14-2008 12:18 AM
sdbadd44
08-28-2007 11:16 PM
