Superchips cortex. what to expect?
Old 07-02-2011, 05:05 PM
raminator01's Avatar
its a huge difference the butt dyno is loving it!! I still havent chirped second. I have 245/40 neo gens and it just lights em' up on full throttle in first..
where's a good place to pick up one of those zzp downpipes?
raminator01 is offline
Old 07-03-2011, 02:22 PM
2010SilverIceSS's Avatar
Direct from ZZP. On the catless dp, you will have to extend your exhaust tip about 1/2" on the automatic.
Dave
2010SilverIceSS is offline
Old 07-03-2011, 08:04 PM
ATLsilverSS's Avatar
Dave
but im a 5spd
ATLsilverSS is offline
Old 07-03-2011, 09:05 PM
http://www.zzperformance.com/cobalt_...1016&catid=187
is that the correct catless d/p??
Old 07-03-2011, 09:23 PM
  #26
Yep, thats the one. They have more options now than when I bought mine. Go with the offroad w/ o2 bung one. Depending on mileage, you may or may not need a gasket set. I only had like 5k miles and mine looked brand new. Most of the time you can reuse them as their metal gaskets. Wouldn't add a wideband bung unless you want to buy a wideband gauge only. But, you would be better off with an Interceptor which would monitor it for you. If you had the RPD, you could monitor A/F off of that. Best bang for the buck bolton you can do when adding power to these little engines.
For your muffler delete, did you just weld a straight pipe in? I've heard muffler deletes/catless combos are very raspy and rice sounding. Just some info to think about. I believe there are cobalt videos on youtube you could listen to. Of course, I drove straight dumped for a couple hours and it would rattle all the windows about 3500 rpm. For me, stock muffler and catless was perfect. A little loud at start up and pretty quiet while cruising and idling. Once it got past 3500 rpm, it would become an animal.
Dave
Old 07-03-2011, 11:13 PM
  #27
it is just a piece of pipe welded in.. the people did a half a** job. when i get back to oklahoma in august im going to have my exhaust guy fix it and put a spintech muffler in there..
how much power should i expect to gain with the catless d/p?
Old 07-04-2011, 11:41 AM
  #28
Originally Posted by raminator01
it is kist a piece of pipe welded in.. the people did a half a** job.
what are you referring to in that quote?
as far as gains....probably 15-20whp depending on your other mods, tune, etc. it really opens up exhaust flow greatly reducing backpressure.....very noticeable
Old 07-04-2011, 02:03 PM
  #29
fixed it! sorry this mac computer is on its own program sometimes..
thats going to be my next mod.
then some depo black headlights and having my windshield re tinted!!
hhrboutique
06-07-2009 05:09 PM
Quick Reply: Superchips cortex. what to expect?
