Turbo Upgrade boost questions
Old 01-19-2012 | 12:56 PM
So I FINALLY got my upgrade kit installed yesterday! Yep,big improvement. Even the tech came back from the first test drive with the "SS grin" on his face.
Heres the questions: Boost is only topping at 17lbs(60 degrees, low humidity,sea level). Is this a problem? Thought it would over 20. I ask the tech about it, but since this was his first install,he wasn't sure what it should peak at. Stock boost read 13-14.
Any thoughts on this would be appreciated. Thanks.
Old 01-19-2012 | 01:07 PM
I have heard your 17 all the way up to 24 for the stg1, mine does 20-21, till I turn on Trifecta, then 24-25 you would like it, over 20lbs makes that smile impossible to get off.
yosemitrsam
22
08-28-2013 08:13 PM
Sasksurfer
07-07-2009 08:25 PM
foggypeake
10-18-2008 09:48 PM
