2.2 Air Cleaner Removal
Old 10-23-2008 | 02:36 PM
Krusty's Avatar
Red face 2.2 Air Cleaner Removal
Anyone know how to change the air cleaner? The manual says the entire assembly comes off and then there are screws holding it together. I can't figure out how to remove the housing from the engine and don't want to force it.
As well, does anyone think a K&N filter is worth the money?
Thanks!
Old 10-23-2008 | 02:39 PM
Here's a great "how to".........
https://www.chevyhhr.net/forums/maintenance-upkeep-50/checking-replacing-air-filter-10757/
And here's one vote for tht K&N filter. Changed over to one at about 20K.
Old 10-23-2008 | 02:53 PM
esmarkey's Avatar
Man, I used to replace my air filters by twisting off one wing nut
If you go the K&N route just don't over oil it! It will foul up the MAF sensor if you do.
Old 10-24-2008 | 12:13 AM
HHR Nole's Avatar
I went with the K&N in my stock box.....seems a little peppier. Air box is held on by 3 gromments , put a little water proof grease in the eyelets when you put it back together,makes it easier to pull box next time.
JCC
Maintenance and Upkeep
14
07-04-2015 06:18 AM
F-16C
07-14-2013 11:15 AM
Silverfox
07-08-2011 01:49 AM
Reb317
05-18-2009 02:46 PM
08blackHHRSS
02-14-2009 04:58 PM
Quick Reply: 2.2 Air Cleaner Removal
