Battery Charging
Battery Charging
Do I need to remove the battery in order to charge it or can I connect the battery charger from under the hood using the positive & negative connection points by the fuse box?
Fred.
Fred.
I would charge the battery in the car (with the hatch open) but I would suggest disconnecting the battery terminals, just in case. Also be sure to charge it with the correct amps and for the proper amount of time to avoid any overflowing of acid from being over charged. If it is a maintance free battery dont add water to it, most people over fill the battey and cause it to leak during regular(proper) charging and then try to say the battery is junk. Sorry I work in auto retail and hear these stories too often. Just a tip, the acid in the battery should just cover the lead plates, it doesnt need to fill the whole cell.
I bought a nice charger from Sears that does 2 Amp trickle, regular charge (I believe about 20 amp) plus it you can start the car off the charger. Plus, I picked up a batter booster pack for 29 bucks on sale that I carry in the car for emergencies. Plus I have helped out neighbors several times with it. Much easier than using booster cables
kmcrae476
05-25-2015 11:19 PM
