Cherry Bomb Vortex muffler
Old 02-17-2009 | 01:31 PM
BigBeefer's Avatar
I have been looking at this muffler and had a couple questions:
1. What inlet/outlet configuration is needed for the HHR so that the tip exits the factory location?
2. What diameter muffler should be used? I assume the 2.25" diameter muffler, is this correct or no?
I have the 2.2 with the stock exhaust. Thanks for any info!
Old 02-17-2009 | 01:43 PM
masterchief1112's Avatar
1. center./center should do it
2. just get underthere and measure it if you can get the circumfrence of the pipe you can get the diameter.
Old 02-17-2009 | 03:51 PM
BigBeefer's Avatar
1. From what Ive read on here, center in/offset out is needed, I just want to confirm this.
2. From what Ive read on here, 2.25" diameter is needed, I just want to confirm this.
Thank you for you generic answer though
Old 02-17-2009 | 07:38 PM
The Curly 1's Avatar
Mine is the Vortex 88101 Cherry Bomb
Mine is the Vortex 88101? (I think) Cheery Bomb muffler and it is really nice. I think it is the best sounding one I have ever heard. Not very loud but has a nice tone to it. The muffler is also one of the most free flowing ones made so it will not creat backpressure.
You will really like it.
Old 02-23-2009 | 11:40 AM
BigBeefer's Avatar
Are you sure on the 88101? That has a 2.25" offset inlet/offset outlet.
Old 02-23-2009 | 11:28 PM
I am going off of my memory.
Try the 88100 that should be it.
I am going off of my memory but I think that is right? Call Brent Florus at 979-743-4521 and he can help you. Tell him you have the HHR and you want the same muffler I ordered. I think mine is the off set inlet and center outlet 2.25
Hope this helps, Curly
frey55
Mods - Engine/Exhaust
05-08-2011 04:35 PM
1Panel2NV
02-21-2009 09:13 PM
The Curly 1
2.2L Performance Tech
16
01-10-2009 06:59 PM
nabate
2.4L Performance Tech
05-18-2006 04:32 PM
