Exhaust tip
Old 05-05-2007 | 08:49 PM
dadd75's Avatar
Question Exhaust tip
I purchased a rolled tipped stainless steel exhaust extension for my muffler and am wondering if the rolled tip will cause any problems with the exhaust?
I have not installed it, bought it from Gibson Performance.
Old 05-05-2007 | 09:04 PM
Can't see how. Go for it!
Old 05-05-2007 | 09:22 PM
captain howdy's Avatar
It's just for looks. You won't change your exhaust any other than making it look better.
Old 05-06-2007 | 10:27 AM
Desert Coyote's Avatar
That would be correct. As long as it's centered and tight, it won't affect anything. Only problem I might see happening is if there's a screw loose on the mounting, or if it's off-center, and at that it'll just create a bit of a rattle.
Old 05-06-2007 | 10:51 AM
courthousedeb's Avatar
I looked at Gibson's website and would venture to guess this is the one you got. Very nice looking exhaust tip.
http://www.gibsonperformance.com/products.asp?pid=19843
It does feature the built-in clamp at the end of each tip that speeds up installation, however, I would have it welded for several reasons. One being the possibility of theft and the other being to make sure it doesn't jar itself loose over time.
Old 05-06-2007 | 01:37 PM
dadd75's Avatar
Thanks
Thanks for all your responses! the tip shown is the one I have. Once I get this on and my chrome trim on the tail lights, I'll have a pic for all to see.
Old 05-16-2007 | 07:17 PM
outlandishhhr's Avatar
Just a note about that tip, you will need to drill a small hole in the bottom so it can drain, I had the same tip on mine and I didn't put the smaill hole on it and it started to rust and looked awful, i recommend getting one without the rolled end, though.
Old 05-17-2007 | 06:54 PM
Size:  5.6 KB to the site outlandishhhr!!!
Old 06-18-2007 | 10:48 AM
rhoss1's Avatar
Hey, Mine is just like that and its the best looking tip out there. [IMO]
rhoss1
jship2007
2.0L Performance Tech
12
12-20-2012 09:10 PM
08SSREDHHR
29
02-23-2012 10:33 PM
SKECHER
2.2L Performance Tech
02-18-2012 06:46 PM
jujuss
05-10-2008 06:27 AM
