front end noise
front end noise
i have had my 06 hhr for two years know. i have not had much trouble with it but now the front end is making noise. i know this is a on going problem with the hhr took in for service they said they could'nt find any thing wrong.but the noise is still there.has anyone found out what might be causing this noise it is more noticeable when the weather is colder.
I had a friend that bought a new Mercedes and it had a noise that drove my friend nuts. It keep taking it back and when the service manager told him it was withen tolerance he traded it off for a Lexus. So I guess what I'm saying is nothing is perfect.
See ya down the road
Bud-Harvey
Bud-Harvey
I was planning to take mine in for the same issue, but now it's warmer and there's no noise for them to diagnose...The transmission now shifts much easier, the syncros baulk a little when the oil is cold. Still a host more rattles in the interior trim and headlining too.
My dealer replaced many parts looking for the source. Finally installed new sway bar bushings (the cheapest, easiest part they replaced), noise went away. Might be worth a shot since they are pretty cheap and easy...
I hope this is not the same noise my balt has, bc if so you will have it 4ever, right now im trying to make a deal with the dealer, bc I have taken my balt in 7 times now and still the noise keeps coming back... I hope is no the same problems bc I want to get the HHR. what model of HHR you have? is it base model? is it suspencion noice, when ever you go over a speed bump or irregular roads..?
