G Force Performance Chip for 2.2 L
Unfortunately, there's not a whole lot of power in these things if you keep it N/A. You could go cammed like this guy:
Even with all the stuff he's done though, he's only making about 185whp, up from around 125whp, so only about a 60whp increase.
As Snoopy said...save your money. However, if you want to save money and still try it you can make your own "chip". What this G Force chip does is fools the computer into thinking the air coming into the intake is colder than it is. This is done with a 4.7 ohm resister in line with the AIT sensor for a 10-12 degree drop in air temp reading by computer. You can get a 20 degree drop by using a 5.4 ohm resister. The temp drops are approximate. I have never done this on an HHR but have on other vehicles. There are all sorts of 'how to's' on this. On Google just type in "home made 'power wire' on Dodge truck". There's at least a half dozen videos on youtube and write ups.
A tune is truly the best way to go. The G-chip is not very good. In fact, if you do get a tune don't use a G-chip as the tune advances your timing and the G-chip could cause too much advance possibly causing pre-ignition and engine damage.
Did you actually have the 10-12 degree drop with the 4.7 ohm resistor and/or the 20 degree drop with the 5.4 ohm resistor? Then using the generally accepted engineering principal of 1 HP for every 10 degrees, you were only able to recognize 1 or 2 HP........correct?
To tell you the truth I hardly noticed any difference at all. Perhaps like a cool morning when your engine feels like it has a slightly more pep. I only ran it a few days as I had to go to the dealer for some service and I was concerned it might void my warranty if they saw it. When I was through with the dealer I never bothered to put it back on the truck.. I never actually tried the 5.4ohm but went by information others had posted and because all their posts were approximately the same results I just accepted it as good information.
Thanks for your answer !!
And your answer appears to be in line with the rest of the info. I doubt if anyone would feel a 1 or 2 HP gain, so yeah I can understand your doubt.
But your total info I did find interesting. It provides the truth in advertising to prevent any liability. You know, the old...."......up to 30 HP gains.....". Many aftermarket parts providers use that terminology because potential buyers focus on the number value ONLY, thus increasing sales.
Alas, many here have believed it.
