Has anyone upgraded the cams/cam?
Old 04-22-2009 | 09:06 PM
Panel08's Avatar
I found this one online. What do you guys think would it be a better performance and sound? http://www.eautoworks.com/product-Co...VROLET-HHR.htm
Old 04-23-2009 | 05:14 AM
masterchief1112's Avatar
yeah its 2 cams, people do it with the balts and the cavys but i have not heard of anyone doing it to the hhr. it will make your car idle like hell and from what ive read for little gains, check out www.ecotecforum.com, all the stuff you would ever need to know about ecotec performance is right there.
Old 04-23-2009 | 01:27 PM
Panel08's Avatar
what do you mean it will idle like hell? you mean itll be really loud at idle?
Old 04-23-2009 | 03:04 PM
it will idle very rough, i guess it will sound and feel like your engine is trying to escape from what ive heard. if youve never done cams before i would find a pro to install them, also have a tune ready to go. you dont want to screw up the timing. its not just as simple as opening the head and droppping in new cams
Old 04-23-2009 | 04:55 PM
Panel08's Avatar
but thats what I want I want a more chunky sound and definetly would have someone else install them where would I get the tune? you say itll idle rough but a good kind of rough right lol
Old 04-23-2009 | 05:07 PM
catdaddy137's Avatar
2.4?
maybe you can put the 2.4 head on ?? if not , maybe the 2.2 with that cam would be better with different valves ? as well as it would definatly need a tune.
Old 04-23-2009 | 05:53 PM
Panel08's Avatar
no for a 2.2 I want the chunky sound and Ive been told the best things for that would be cams and a header
Old 04-23-2009 | 06:03 PM
oneton's Avatar
I just want to ask What is the lift, What is intake & exhaust over lap, What is deg res of duration, what offset, The answer to the ? is how it will Idle, Run & sound
Old 04-24-2009 | 04:10 AM
you cant put a 2.4 head on a 2.2, the 2.4 has VVT. get the tune from trifecta tuning, chevy hhr world is a vendor for them. also did some reading for you, it sounds like you dont want to go above a stage 1 cam. with that most of the petrol heads on ecotecforum.com say new valve springs, 2.4 intake, bored throttle body, or the 2.4 tb also. and they say thye stage ones dont require a tune but to get your money out of them you will want one.
Old 04-24-2009 | 07:24 PM
Panel08's Avatar
are the ones on the link stage one? how would I know the ones on the link are the only ones ive been able to find
