New Header for my HHR Panel
Just purchased a Nice looking Header off Ebay, has anyone already installed this one.
Will it be a simple swap with the original exhaust manifold, is there anything I should know before I start this project.
Once completed I will be installing a 2.4 intake manifold for my 2.2 ecotec.
http://cgi.ebay.com/ebaymotors/Stain...Q5fAccessories
Thanks
Thanks
Thanks
Thanks
Can someone confirm this?
The color is a function of material thickness and temperature. It will definitely turn at the inlet point as the exhaust gasses rise in excess 1000°F. There is no solution for this (except to retain the stock cast manifold, which is also discolored by the heat, but not typically noticable).
I think a couple hangers need to be relocated and it will need to be shortened a couple inches. Should be doable though.
