Quick question..on 2 mods (intake and exhaust)
Those mods on a 2.2 shouldn't cause any issues. But. If it does throw a CEL,then you might be looking at a reflash or possible tune.
Do not over oil the K&N filter. They have been known to mess up some Maf sensors.
X 2
Check the K&N filter for "over oiling" right out of the box, if it seems excessively oily, just blot it with some paper towels.
Make sure the intake kit you pick has some distance between the filter and the adapter where you re-mount the factory MAF, you should have about 8" minimum to avoid contamination by any oil mist from the filter.
foolmoon_design
2.0L Performance Tech
26
04-07-2011 12:44 AM
