Sway bars..
Sway bars..
So is there any other option for sway bars in the 2.2? Do we even have a rear/front sway bar? I know from my other ride, stiffer bars equals less of a lean in aggressive turning etc. Same with this?
So stock sway bar width?
Both a front and rear?
There's sorta a torsion bar between axles..so by adding a bar your augmenting the system. You can get specs online , I believe they were posted in some of the new car review s. A rear bar on these cars does wonders!
As was mentioned rear is a type of torsion bar, not removable from rear axle.
Front sway bar is plenty imo.
Rear kits are simple bolt ons... Use the "Search" function & you should find plenty with pics etc..
I have the 1" rear bar on mine..
I did a search in the 2.2 section. Either didn't word it right or really only 2 threads. One was about brands. Other one had no responses to it.
I just dont like high speed cornering with body movement.
Search box is in the upper toolbar. Click on the arrow & a drop down window appears, type in the search (use only 'key' words), & see what pops up..
Like this:
https://www.chevyhhr.net/forums/show...t=sway+install
On mine I swapped rear springs for Cobalt SS/TC springs, that lowered the rear 1-1/4", which was a big help. Then about a month later added the 1" rear sway bar.
Like this:
