Camshaft alignment
Camshaft alignment
I have a 2006 2.4 hhr that I just rebuilt the motor on. I triple check the timing marks on both the balance shafts and the camshafts, and they all line up. Balance shafts, exhaust at six o'clock, intake at 12 o'clock, crankshaft sprocket at six. The camshaft sprocket exhaust at 10 o'clock and intake at 2 o'clock with the crankshaft sprocket at 5 o'clock. When i try to start it, the motor sound like it does not have any compression. I took the valve cover off and turned the motor over my hand. I notice that as soon as the intake valve on number one cylinder opens and then closes that the exhaust valve begins to open. I know that the exhaust valve should not open until after the combustion or power stroke takes place. It seems to me that one of the camshaft are 180 off, but if I turn it, the chain links will not line up. any suggestions.
Oldblue's illustration is from a different article. Not the chain article. Mine are correct for replacing the chain; step 1 is the crankshaft, step 2 is the intake, step 3 is the exhaust (the exhaust gear should be off installed with the chain)
The exhaust is the one closest to the exhaust manifold. I think the 2.4L has 2 different shafts 12578515 for exhaust and 12578511 for intake.
DO NOT TURN THE CRANKSHAFT COUNTER-CLOCKWISE.
Once you turn the crankshaft you need to take it all apart and start over; it takes a lot of revolutions to get back to lined up.
