Exhaust mods?
Exhaust mods?
Hi all! My supercharger and intake manifold came in last month, I'll put them on and document the install at the end of this month.
While I'm doing it, I wanted to do some simple upgrades to the exhaust system and was looking for suggestions. What do you all recommend? I've read headers, downpipe, and catback exhaust but I wasn't sure what or where to buy some good ones.
Looking at these:
05-10 Chevy Cobalt / HHR / ION Racing Downpipe CatBack Exhaust Replacement Outlet Piping
05-10 Chevy Cobalt 2.0 / 2.2 4-1 Design Stainless Steel Exhaust Header Manifold - Black
As always thanks! So much info out there, but you folks are always the best resource.
Looking at these:
Your going to have fun with the supercharger.
You might consider getting a Dual Pass kit from ZZP for your heat exchanger.
That Ion racing down pipe is just the flex pipe section. If you look closely it is the crush ring type. I had one till I tried to get a new crush ring. Not easy to get. I changed every thing to the Trubendz system.
I used a ZZP shorty header. They stand behind their products. Mine cracked and I sent it back and had it back in just a week.
TruBendz has a 3" and 2.5" down pipes with reinforced flex pipes for supercharged cars. I have the 3". They also carry cat back pipes from 2.5 to 3." at very good prices. They will custom bend and build your pipes.
Muffler is your choice. You will need a little back pressure to keep the bottom end torque, but you want it still to flow to get the top end.
Consider a water meth system to help knock.
Good luck.
Good luck.
A better down pipe and a good low restriction cat with a good cat back system is the best bet. What you need to see in the exhaust system is not only larger diameter but smooth bends inside...if the are wrinkles where the pipe has been bent it affects the flow and decreases performance. Buying from any well known manufacturer should give what you need.
Don't be afraid to call the manufactures Tech/Support lines and ask questions.
Butt dyno is accurate enough in this situation. It is immediately noticeable. There are numerous ways to measure differences on the street. MAF readings are a good indicator, but acceleration data is the best method.
dustin6119
2.2L Performance Tech
06-06-2012 04:26 PM
