HHR Performance Module +25HP Kit
I have never heard of it but after reading some of the feedback and looking it over I can tell you that is is not a computer chip. If it were a chip you would not have to cut any wires. With aftermarket performance chips you just clean the contacts on you computer and plug them in. I had to run a wire on my last car because I used a flip chip (3 positions 1-factory,2-high performace,3-custom) but I didn't cut anything. I have installed and help install several chips and have never seen one that you have to cut into anything. Whatever they are selling might work but I doubt it. Buyer beware!
I haven't used that brand of performance module butb I did use another that I think is the same type. If it hooks into the air temp sensor it's the same and they do work. I had one on my frontier, It was a good product.
If it sounds too good to be true
If it sounds too good to be true it probably isn't. Manufacturers put a lot of time and effort to put out their vehicles in as good a as mileage and operating condition. Don't you think that if there was a way to cheaply increase mileage or power, the manufacturer would do it?To pass the EPA testing the motor has to be in top tune, or it won't pass.
