K&N air box?
Old 04-05-2009, 02:56 PM
Hib Halverson's Avatar
K&N air box?
Anyone here tried the K&N Fuel Injection Performance Kit (FIPK) on a 2.4?
If so, what were the results?
Hib Halverson is offline
Old 04-05-2009, 04:53 PM
Former Sponsor
TurboTechRacing's Avatar
If you are refering to K&N part number 63-3056 we have sold a few. Around a 10HP gain...
Can be found here:
http://www.turbotechracing.com/produ...idproduct=5067
And in stock :)
TurboTechRacing is offline
Old 04-06-2009, 11:57 PM
Panel08's Avatar
can they be used on 2.2?
Panel08 is offline
Old 04-08-2009, 05:57 PM
Former Sponsor
K&N only shows it fits the 2.4L at this time... Anyone else verify the intakes are the exact same between the 2.2 and the 2.4L?
Old 04-08-2009, 06:35 PM
HipHotRod's Avatar
I can hear Joe now..................5, 4, 3, 2, 1
HipHotRod is offline
Old 04-08-2009, 06:42 PM
Panel08's Avatar
HAHA yea where is he?
Panel08 is offline
Old 10-14-2009, 10:17 PM
Can be found here:
And in stock :)
Ok.
Based on "TurboTechRacing's" earlier post, back in Sept. I took my truck out to K&N and had them install the Fuel Injection Performance Kit for HHRs then run it on one of the chassis dynos on K&N's R&D department.
The performance increase wasn't quite 10-hp but it was credible. Executive summary: on average an increase of 8-hp and 6-lbs/ft torque, SAE-corrected at the front wheels. In addition to the convincing performance improvement the K&N had none of the fit problems I experienced when I tested the Airaid intake kit last year on my HHR five-speed. For more info on that see the following threads:
https://www.chevyhhr.net/forums/show...=Airaid&page=2
https://www.chevyhhr.net/forums/show...ghlight=Airaid
The K&N also is better looking that the Airaid. Lastly, unlike the Airaid which is open in the front, the K&N FIPK fully encloses the filter which I feel is a better design.
In a few days I'll post a more detailed account of my experiences with the K&N FIPK.
Old 10-15-2009, 08:08 AM
RaineMan's Avatar
I went with the Airaid instead because of the lower cost. I believe performance between the two is similar... it just depends on whether you want a complete box or just a cradle.
RaineMan is offline
Old 10-15-2009, 06:33 PM
hhrcrafty's Avatar
I doubt anyone's going to feel anything from any cold air intake without a real ECM tune for the new airflow. From what I've discovered in the Mustang community, nobody running a real performance car just bolts on a CAI. Everyone expects to pay for a tune that'll maximize the performance of the CAI and wring every last bit of power out of the new airflow.
That is, of course, if you believe that the stock airbox loses more airflow than the plastic tube you're bolting on in its place. Or that the intake tube diameter on the aftermarket CAI is any bigger or flows more air than the stocker.
hhrcrafty is offline
Old 10-16-2009, 08:41 AM
RaineMan's Avatar
Well, the filter on an aftermarket intake obviously poses less restriction than the stock one does. As far as "feeling" any gains from just bolting the unit on... it's not gonna happen. These intakes gain 10hp at most, you can't really feel that.
On the tuning subject. A good retune is going to make the most out of any modifications to your engine. That being said, if you are planning on adding multiple bolt-ons over time (intake, header, exhaust, etc.) it is simpler to wait till you are done and get retuned once.
RaineMan is offline
