MagnaFlow Cat Back
Not on yet, trying to decide if I also want to change out my CGS to a K&N.
But after the 1st it will go on.
Curious about the sound. I wouldn't expect a performance increase unless you categorize sound under performance
You still gain some power with the CGS due to a less restrictive air path.
The temperature of the air has less of an inpact on performance than the number of restrictions in the path of the air. Yes the colder the air the better, but flow is better than temperature in the big picture, since the MAF will dump fuel in if it gets too cold thereby decreasing performance.
To make the CGS get colder air run the filter to the fender, all it takes is a silicone elbow and a small section of pipe, really not hard and only takes a few minutes, plus she wouldn't be spending $225 on another intake system if that was the reason for her switching.
I personally have the CGS intake it (in my experiance) does improve the performance of the vehicle a good bit. While using cruise control going up a hill I go up EVERY DAY the T.C. would lock up within seconds of going up the slope in stoc form stock, after the CGS it would go half way before locking up, after the Magnaflow cat-back the T.C. doesn't even kick in and it stays one consistant RPM all the way up the hill.
Im not trying to start a flame war, nor am I trying to "jack" this thread, just wanted to ask KAREN a question. And I will still wait for her to answer.
#27
You can't say without the shadow of a doubt the K&N would gain any more than the CGS, the stock system, or any other system avaliable for that matter, that would require an indepent side-by-side dyno test which NOONE has done.
The stock intake is not restrictive at all and probably flows better than the K&N and the CGS anyway.
#28
How can you possibly say that the stock intake flows better, it has 4-5 chambers in a huge box that the air has to navigate around in order to even reach the throttle body.
Tourque converter locking up and downshifting goes hand in hand with an automatic.
#29
If you guys wish to continue to argue the merits of the intake systems, you might want to look up the dyno charts that JoeR posted on this forum. It kind of confirms one poster's assertions and corrects the other poster's comments.
