Sounds like a diesel after timing chain replacement
Hello
First time poster here. I have a 2006 with the 2.4 engine. It has 111280 miles on it. Timing chain was starting to make noise when I started it in the mornings. I just had the timing chain and balance shaft chains replaced and now it sounds like a diesel when it idles . What would cause this. Its going back to the shop in the morning.
Thanks in advance Randy
Welcome - sorry to hear you are having problems after getting that work done.
It's hard to say what the problem is - best to just let the shop check it out. They may have left something loose: guides/tensioner, or a defective part etc..
I'd be leery of driving it in case it has jumped a tooth or such, and ends up bending a valve or causes other damage.
Update
Hello
Well just got back from the repair shop with my HHR. It was a defective tensioner. It was the one that screwed in on the back side of the head. They replaced the one that was in the timing chain kit with another new one. Now everything is quiet and it runs great.
Thanks for all the replies
Randy
Randy
