tight fit
There are 3 bolt on the reservoir, 2 on the top and 1 on the bottom aside the pump wire grommet, I just make the top front hole(If you are on the passager side and you have the reservoir in front of you, it the RH bolt) off the reservoir a bit horizontaly bigger to bring the reservoir closer to the fire wall.
tight fit trouble
Lots of noise under the hood. I popped the hood & what do I see.
1 outlaw filter flopping around loose well not flopping (not enough room)
also my cord for the block heater rubbing the crank damper.I' glad the belt
did not grab that cord ! It took about 5min to fix
later rNr // mike
later rNr // mike
Here my installation pick Click here !
Great post. When it warms up I'll take mine back out & redo as per your
instructions
rNr // mike
bigjacksauto
Maintenance and Upkeep
12
06-14-2012 08:53 PM
