Timing guide Upper bolt replacement.
If you watched the You Tube Video by Ted from Havuk Industires on purchasing and replacing the weak Upper guide bolt, he makes comment near the end that there is also a problem with the Lower guide bolt breaking and he is going to figure out a fix and make a video.
Does anybody know if that ever happened and why wouldn't you replace it at the same time as the upper bolt?
Silverfox
Silverfox
I have sent an E mail to Havuk Industries. Let you know if I get a reply.
The block he shows in the video had a broken lower bolt showing.
Does the SS 2.0L have the same issues?.
RJ_RS_SS_350
"How To" Tutorial Library
33
06-21-2021 10:12 AM
