Aftermarket Fog-Lights...
Hi All!
Been thinking about installing some fog-lights on my HHR. Any suggestions to as what are the better aftermarket fog-light kits for the HHR that still retain the same look as the stock ones.
Thanks in advance,
-David
Thanks in advance,
-David
Originally Posted by D.Levesque
Hi All!
Thanks in advance,
-David
Thanks in advance,
-David
They are around 5" diameter, but if your looking for the stock look you can get the factory fog lamps from your GM dealer. I just installed mine. GM is already on their second design. They aren't cheap but are easy to install. You can also get the factory fog switch. You should be able to deal on the price with your dealer.
15813308 Lamp (left?) List $78.75
15813307 Lamp (right?) List $78.75
21992589 F-Switch List $29.33
The wiring for the switch is already there but it is a monemtarty and it appears the body computer needs to be programmed to enable the fog lamp relay. Any experts out there on this??
"They aren't cheap but are easy to install..."
Really CJ? I had heard from Erich at Darkside that unless you get the factory setup, there are no brackets on the frame to attach your lights to. Have you already mounted yours? Was it difficult? What did you mount to? Thanks.
I seen one where the owner hole sawed the (Vent Plug?) and glued standard 4" fogs to the plug. Looks a lot better than it sounds, but still doesn't look factory and there's no adjustment.
Sound likes I need to take it in to have it reprogram.
ANYONE HAVE ACCESS TO A HHR WIRING DIAGRAM THAT COULD POST THE WIRE COLORS??
I would like one for the stereo wiring please! I was going to put my speakers in on Friday and that would take a lot of guess work and testing out of the way. Any info on the color scheme of the wires would be helpfull. Please, I'm begging you!
