Aftermarket Fog-Lights...
Originally Posted by snksknr94
What part of the schematic do you need, gimme a little more info and I'll pull one tomorrow, just for the fog lamps and lamp controls??
If I could get the wiring diagram from the fuse/relay box to the lamps would be great. Looks like there are three main connectors leaving the primary fuse box. I would assume power to the fog lamps leave the relay via one of these three connector. Wouldn't hurt to get the wiring for the switch too.
Thanks
SNKSKNR94
Any luck on locating a wiring diagram? :)
Hey guys, thanks for the great reply's!
I didn't get the HHR with the fog-lights because the only one's they had up here had all the stuff I didn't want (LT's, rims, leather, etc.) and as it was they had to ship my car from another dealership (Calgary to Edmonton) out of town so alas... I settled for the one that had the specs I wanted minus the fog-lights.
Now that I'm informed (again, thanks!) about all the work etc. involved I won't be messing with the installation, leaving that to the professionals but still looking forward to the diagrams!
i just ordered the factory fog lights, i checked behind the wheel wells, and i have the prewiring for the fog lights, just to verify once i place everything in and wired, due i need to have the BCM flashed for them to work or will they work with out the flash?
You will most likely need to have them programmed in the BCM. Did you check both sides when you looked for the wiring. I made the mistake of only checking the passagers side and saw what I thought was the wiring for the fogs, turns out it was was a temp senser or something. Didn't realize it until I checked the drivers side and there was nothing. A quick Ohm test verified that it was not for the fogs. Not a big problem though as wiring them is wasn't too bad. Check out the "How to Section".
Thanks I will check the Drivers side tonight when I get home, I did see the "How to" that is what inspired me to do the install myself.
AfterMarket Fog-Lights Installation
[FONT=Arial][COLOR=Navy] I'm not exactly what you called "mechanically gifted". Would anybody have any idea where I could get my fog lights professionally installed. Would I be able to take it to pretty much any place where they install stereos?
