Automatic Shifter Knob Mod
I'm looking to replace my automatic shift knob with something like a MOMO. I have a few questions:
1. Anyone know how difficult it is to remove the stock?
2. Also, is the lever that allows the selector to get out of "P" called O/D or is that something entirely different?
3. Anyone else have suggestions on other brands or types of knobs? I'm trying to keep the retro theme of the HHR so no pistol grips or straight sticks.
All feedbacks welcome...
Did you guys try http://www.twmperformance.com ?
Please tell them Jonel from chevyhhr.net sent you :)
Hi Guys,
We haven't had the opportunity to look at the HHR shifter yet, however we have shift knobs for virtually every application thanks to our new NTIS shift knobs. If someone could post a picture of the shifter I may have some insight on how to remone the knob and whether we have a shift knob that would work.
To read more about our NTIS knobs, check out the article on www.twmshiftknobs.com, here's the link:
http://www.twmshiftknobs.com/column/index.html
along with a diagram of how the new height adjustable knob works:
If the shifter shaft is threaded, our knobs will certainly work. If not, we can do a production run of non threaded inserts specifically for the shaft diameter. I'll see if we can get an HHR in to the shop this week to have a look, but until then it would really help if someone could post a couple pics of the stock shifter and knob.
Thanks!
Kevin
TWM Performance
Thanks!
Kevin
TWM Performance
TWN Performance. Do you deal with "Automatic shift knobs"? I couldnt see any on your site, but maybe I'm looking wrong. I got a pic of an automatic shift knob since that is what we are tryin to find.
Way crappy pick had to use flash. I'll take a good picture tomorrow.
Okay, as I stated earlier the shift lever is the same as my SAAB (except for trim). Here is the instructions from a SAAB forum... http://www.saabcentral.com/users/vis...eplacement.pdf
