Chevy HHR Wheels
If you get a 20x7.5 with the proper offset and run with a 225/30/20 tire it shouldn't be a problem. Most aftermarket wheels are 20x8.5 and have not enough offset which will cause major clearance issues. There are some 20-inch wheels listed on our site that have the proper fit and when run with the tire size noted above will not require modification to run on your HHR.
http://www.truckshop.com/home.php?cat=882
Charvel1975
Tires & Wheels
09-03-2014 05:22 PM
