costs to install triple lake pipes
Old 07-24-2006, 11:17 PM
Question costs to install triple lake pipes
I know Sindy made a deal with the devil and got someone to install hers for $40, but what have the rest of you paid?
Gonna be looking for a shop later this week and would like to have an iadea of what to expect. Thanks.
GDZHHR is offline
Old 07-24-2006, 11:22 PM
cj krause's Avatar
i did mine myself, used the chrome clamps,,, took me lil less than an hour
3.5 inch stove head bolts for by the side and short stove head bolts for under the body
cj krause is offline
Old 07-24-2006, 11:26 PM
Any chance of you reposting your pics of the install?
They're not in the old thread anymore, thanks.
GDZHHR is offline
Old 07-25-2006, 12:07 AM
BlackHHR's Avatar
Got some prices for my 70" side pipes. Not going to post how much it will cost to get them working, but lets just say I'll be doing it my self. And yes I'll post pics.
BlackHHR is offline
Old 07-25-2006, 09:35 AM
EZ4U2CHere's Avatar
Now that's what I want to see, functional!!!
In my opinion it looks weird seeing exhaust pipes out the side with a muffler sticking out the back.
EZ4U2CHere is offline
Old 07-25-2006, 09:45 AM
flyhhr's Avatar
right!!!!!! looks like chrome running boards. Not my thing if they don't work. Or atleast if your going to have them shorten your real exhaust to where the pipes come out so you get kinda the idea that they are coming out at the ends
flyhhr is offline
Old 07-25-2006, 05:23 PM
cj krause's Avatar
here are pics and how i did my pipe install myself
The car was dirty, sorry, drove in some sprinkler water this morning going to teach.
The pics are labeled and there is an angled wall on the inside where I drilled a small hole and then ran the stovehead bolt up all the way into 2 walls (outer and inner further up the inside) on the outside bolt. The inside bolt just needs a 1.25 to 1.5 in long bolt to go into the body. I just used a drill and drilled the bolts on through.
The placement pic on the front clamp is obvious to the lil rectangular hole on the side and the back one was done around 1 inch from the lil sidewall that goes across that channel under the car on the side.
both sides were the same and the placement worked on both sides. hope this helps
Once you have the washers and bolts and drill small tap holes on the angled wall the install is very very fast. You can loosen the bolts and roll the pipes a little, not a lot.
Front clamp and bolts and placement
Back
Old 07-25-2006, 06:26 PM
BlackHHR's Avatar
Looks Like I'll have to get a nother new muffler to put in to the tunnle under the car. About 800 to get it all done here in Saskatoon. If I can't do it my self I'll take it in to get done. I'll most likely be selling my V-Force muffler that I have on there right now. I'll miss the rumble sound that it gives my HHR, but sidepipes are way cooler right.
BlackHHR is offline
Old 07-25-2006, 07:07 PM
cj krause's Avatar
if you moved the cat higher up by the manifold then put the muffler right there and then put in a Y after and ran it to the pipes there is no way it should be that much. maybe 3 to 400 w labor but hard to believe it would be more than that
? is would it work that way?
i thought about doing that and then getting rid of the rear exhaust and muffler. i looked up in the area and there is enough room to move the cat up and put in the 924 and then split off that. IMCO might have a Turbo that has one inlet to duals in the same size as the 924 and then you wouldnt need a Y, just the pipes to the lakes. you would have to drop the lakes low enough to make sure there was no heat damage and we talked about putting in some shielding all the way under the running boards.
Old 07-25-2006, 07:13 PM
BlackHHR's Avatar
There is not enough roon to do that, and my muffler is the same size as a flowmaster super 40. I'll have to cut the pipe off right behind the resanator and weld a new tube muffler to it. Then but a Y-pipe behind that and get 2 bends to get the pipes all the way back to the front of the car and weld them on to the side pipes. They said that It would be better with the 60" pipes, but they can make it work and still have lots of ground clearnce and clearnce from the gas lines.
BlackHHR is offline
Quick Reply: costs to install triple lake pipes
