Economy Lower Grill Protection
#64
IF you use zip-ties, be sure to inspect then regularly and change them if discolored, as they will be subject to lots of heat (especially when the car cools down after running), and the temperature differential will weaken them causing brittleness.
You don't want to lose your protective shield!
#65
I am planning on using zip-ties to secure the lower portion of the grill to the lower bumper using the suggested zip-ties mounting bases. If one breaks it will not be a big deal since the grill is mounted using the two post already there.
