exterior panels help!
Old 11-15-2011 | 02:22 AM
2007blackk's Avatar
hey guys, i wanna wrap some parts in carbon fiber but i know absolutely nothing about cars and i need to know how to remove the spoiler, and also the cheap looking plastic behind the front license plate? if anybody knows how to remove this PLEASE inform me.
also im curious as to how people paint the rear drum brakes, are u guys completly removing the drum from the axle orrrr can i just remove the tires and spray directly on the drum without removing?? all help is highly appreciated
Old 11-15-2011 | 02:35 AM
Pretty simple to remove the rear spoiler, just open the hatch and unscrew the fasteners, here's a thread on installing the spoiler...just check out the photos for the fastener locations and go to it.
https://www.chevyhhr.net/forums/show...alling+spoiler
Here's a thread on removing the front bumper cover, the bumper trim pad just clips onto the bumper cover so you just pop it off once you have the cover off.
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-paint-your-headlights-17720/
You can paint the drums on the vehicle if you wish, just make sure you cover the fenders with something to keep any overspray off the paint.
Old 11-15-2011 | 05:02 AM
2007blackk's Avatar
thanks, do i need to remove the entire front bumper to remover the bumper cover?? or jus pull on it until its freed
Old 11-15-2011 | 06:51 AM
LawDog88's Avatar
Or you could take and brush on the paint on the drums.
Old 11-15-2011 | 07:29 AM
Grizzly old man's Avatar
Not so long ago I had a broken spring in the rear passenger side brake. I decided to replace the brake shoes on both sides along with the hardware package.
I jacked up the rear end of my buggy and removed the brake drums from both sides and proceeded with the job.
Since both drums were off the car I decided since I had a can of gray primer paint handy and a wire wheel already setup on my grinder to clean the drums and prime them.
While the primer dried I found a can of safety orange spray paint in on the shelf, so I gave the drums a decent coat of that.
It caused my brake job to take a bit longer as I didn’t want to smeg up the fresh paint but not that much longer.
As with any paint job the surface prep is the key, get your drums as clean as you can and at least think about wiping them with some solvent or wash them in dish soap, rinse and dry them.
Old 11-15-2011 | 07:46 PM
2007blackk's Avatar
thanks alot guys, im kinda new here still. im lookin to put up pics soon, buttttt. im still curious about the ugly faded black plastic on the front bumper, i want to remove it and wrap it n carbon fiber. so far i have dont the emblems n fiber, the coin tray, the chrome finish around the shifter, the e brake, and some more small things on the inside, ive switched over to royal purple for all of my engine liquids. i installed blue neons to a switch installed where cig lighter was. however, i want a new muffler that will add some power but wont make it sound like a pure ricer, any ideas?? and do u know if that will void my warranty? also lowering.... will that void?
Old 11-15-2011 | 08:43 PM
Snoopy's Avatar
I have a friend who wrapped his black license plate "spacer" in chrome. He didn't remove his. He just carefully wrapped and tucked the mylar/vinyl product on. Came out nice and professional looking.
A muffler shouldn't void a warranty...haven't heard of anyone having trouble with this (unless you run into a really grouchy dealer/service writer).
Suspension changes GENERALLY do not void a warranty...unless it CAUSES a related failure.
But after looking at your profile, you have a 2007, it's already out of warranty, unless (again) you have an "extended warranty".
Your 5 year/100,000 mile warranty is for DRIVE TRAIN ONLY and would not cover the suspension change.
Aftermarket mufflers add no, or very little power.....MAYBE 1 or 2 hp. So do it if you want a better/different sound.
Old 11-16-2011 | 12:33 AM
2007blackk's Avatar
yeeah i bought my 2007 lt from carmax n july of this year with 13k miles. i have a 5 year warranty w carmax or 100k miles. what muffler give the best/deepest sound from ur knowledge??
Old 11-16-2011 | 01:47 AM
I run the GM Performance Parts exhausts on my 2007 and 2011 HHR's and it sounds fantastic, my wife picked out a Magnaflow system for the 2006 and it sounds pretty good too..just a touch buzzy at some rpm ranges.
Old 11-20-2011 | 03:35 PM
pyro panel's Avatar
Former Sponsor
If ya wanna go lower then my opionion go Goldlines..they give ya a bit more than the Cobalt replacements...or go air..
purplebabyhhr
01-28-2015 03:29 AM
hhrlover101
10-02-2012 01:22 AM
centaur1129
Mods - Exterior
04-10-2012 11:45 AM
conn.rod
10
01-27-2011 12:34 PM
