Factory Fog Lights without factory setup
I would like to put factory fog lights on my HHR, but I don't want to have to mess with the BCM, and I really don't care whether or not if it has the factory setup. I was hoping to wire them so that the fog lights automatically go on whenever the low-beam headlights are on? How would you go about doing this? Would you do a quick splice type of setup? Also, do you need to purchase some kind of bracket/mounting type of thing to put down on the bumper where the fog light plugs currently are? Or do the fog lights just pop in without anything extra? Any help would be greatly appreciated.
The factory fogs just replace the plugs. They snap right in. AS far as having them come on with the low beams, not sure how that would work. I just made my own wiring harness and use a switch that is tied into an ignition on fuse. That way they will automatically turn off when the ignition and doors are opened.
Just locate a constant 12v+ source that is hefty enough to run the two lights (fused) and connect that to pin 30 of a Bosch-type relay. Then tap onto the low-beam wire at one of your headlights...which ever one is closest to your relay... and run a length of wire to pin 86 of the relay. Connect relay pin 85 to a ground. And finally connect relay pin 87 to the hot wire on both fog lights. (don't forget to connect the fog light ground wires to ground). So, when you trigger your lowbeams, it will trip the relay and feed the 12v+ thru to your fogs. When you turn on hi-beams, it will turn off the fogs.
Or, if you want fogs all the time, connect pin 86 to your park light instead of the lowbeam. Any time your parks are on...so are the fogs. Hope that helps.
https://www.chevyhhr.net/forums/how-tutorial-library-21/aftermarket-fog-lights-5524/
I started with these and later picked up a pair of the factory ones off EBay. I've never had a problem with them so far. And I use them every morning on my way to work. It is that easy to wire up.
No offense, but I can't imagine installing those smaller fog lights into the plugs like that. It looks absolutely terrible, and should never be done to an HHR.
I bought my factory fog lights on eBay for $83 including shipping. They didn't just snap in easily, they were a pain to get in, but they look killer compared to having plugs.
Any suggestions on where to buy these factory fog lights? I see a ton on eBay, but a lot of them are completely round yet listed for a 2007 (like I have). I know my opening isn't completely round, the top is flat. So how would that make any sense? Where's a good place to buy them from?
