Front Air dam
Old 09-22-2008 | 11:04 PM
The Curly 1's Avatar
Front Air dam
Who makes or how can I make a larger air dam for the front? I want to cut down on the air under the car to lower wind resistance. All drag race and NACSAR racers do it and it is free horsepower and mileage. Plus it looks nice if done right. The stock one is about 1.5" and I am thinking about a 4 inch one. Anybody make one? Thanks, Curly
Old 09-23-2008 | 07:56 AM
Dirtsurfer's Avatar
You could cut one out of plastic, but drag and NASCAR racers don't go over curbs.
Old 09-23-2008 | 08:37 AM
rockone's Avatar
You could probably use black plastic lawn edging. Attach it to the OEM lip with 3M double sided tape. It it doesn't work, easily removed.
Old 09-28-2008 | 10:08 PM
Thanks
Thanks, The lawn edging worked perfect. I had to trim the round egde off and then I used small 10/32 bolts with washers on both sides.
I think it looks good and will try to get some pictures later. Curly
Old 09-29-2008 | 05:56 PM
stranger's Avatar
Well.............Pics pretty please?
Old 09-29-2008 | 08:28 PM
Pictures as requested
Here is a quick picture for you.
I got it a little crooked in the middle trying to hold it up with one hand and drill and put in the screws with the other. So far I am very pleased with it and have not dragged it on anything so I think it will work out quite nice. The bottom is still 3.5 inches from the ground.
Now if I was to redo it I would probably not cut off the round tube that was on it and have it towards the bottom. That would make it about 1 inch lower and more stable and better contour. Curly
Old 09-29-2008 | 08:58 PM
rockone's Avatar
Looks good. I may add one myself.
Old 09-29-2008 | 09:22 PM
White Flash II's Avatar
Great ideal and cheap too Looks Good
Old 09-29-2008 | 10:13 PM
Thanks,
Rockone gets credit for the idea and it is simple and cheap. Thanks, Rockone who ever you are. Curly
Old 09-29-2008 | 10:58 PM
Don Juan's Avatar
are you lowered and what kind of wheels are those? looks good!
